Community
cancel
Showing results for
Search instead for
Did you mean:
RSeip
SSDSC2CT180A3 show incorrect age of 102 years, 38 days.
I currently have 7 Intel SSD's (330, 335 and 530).
6 of the 7 are showing proper ages when examined by SMART monitoring software.
One of the drives is showing an age of 102 years, 38 days.
Can anything be done to correct this?
Tags (1)
Jose_H_Intel1
Hello Tagman, Would you please provide a screenshot of the https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 Intel® SSD Toolbox S.M.A.R.T. details showing this?
RSeip
Jose_H_Intel1
Is this the only Intel® SSD 330 180 GB you have?
Is it using the latest https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 Intel® SSD firmware?
RSeip
This is the only 330/180 drive I have.
Intel Toolbox v3.2.1 reports firmware as 300i
BTW - in addition to the incorrect aging date, the temperature field reports as a blank field.
Jose_H_Intel1
Considering the circumstances I suggest you to get a warranty replacement from your nearest http://www.intel.com/p/en_US/support/contactsupport Intel® support center.
