Hi KMook1;
Greetings from Intel® SSD communities.
As we understand your inquiry, you need assistance to perform Benchmarks on your Intel® SSD D3-S4610 Series 240GB, 2.5in SATA 6Gb/s, 3D2, TLC
Please note the SSD’s read and write speeds found on the product brief and ARK page, are the results from tests ran on a laboratory, using "Ideal Conditions", this means, lab engineers used a brand new, empty SSD, on a temperature controlled room, using very powerful systems.
If there is data on the drive, or SSD is running an operating system, SSD will never reach spec sheet speeds on a real world environment.
There are several Third-Party tools available for you to perform benchmarking on your drive, as an example, ATTO* Disk Benchmark is a free software and can be downloaded directly from ATTO's website www.attotech.com/disk-benchmark however, this website might be hard to navigate, so a good alternative is to download it using MajorGeeks* site http://www.majorgeeks.com/files/details/atto_disk_benchmark.html
Prior downloading and running the software; please make sure you have backed up all of your data, please bear in mind, this operation might compromise your information during the tests; after data is backed up, you can run the ATTO* tool, by opening file bench32.exe (there will be only two files in a compressed folder); select the appropriate drive and click start.
The tests should start and you will see the graphs updating with speed readings for your chosen drive.
Please let us know if there’s anything else we can help you with.
We will be available to help you in any way we can.
Have a nice day
Santiago A.
A Contingent Worker at Intel
Third Party Content: Web Sites and Materials may contain user or third party submitted content; such content is not reviewed, approved or endorsed by Intel and is provided solely as a convenience to our customers and users. Under no circumstances will Intel be liable in any way for any third party submitted or provided content, including, but not limited to, any errors or omissions, or damages of any kind. ANY MATERIAL DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE USE OF THE MATERIALS IS DONE AT YOUR OWN DISCRETION AND RISK AND THAT YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR COMPUTER SYSTEM OR OTHER DEVICE OR LOSS OF DATA THAT RESULTS FROM THE DOWNLOAD OF ANY SUCH MATERIAL. By your use you agree that you must evaluate, and bear all risks associated with, the use of any third party content, including any reliance on the accuracy, completeness, or usefulness of such content. All postings and use of the Web Sites or Material are subject to these Terms of Use and any other program and site specific terms.
Hi KMook1;
Have a nice day
Santiago A.
I don't need to run iops test, just need to know is SATA controller better than raid controler for ssd disk?
Get Outlook for Android<
***Link Removed***
Hi KMook1;
Thank you for your reply to Intel® SSD communities.
We have checked your comments and in order to provide a recommendation for your application, we will need to learn some additional details about your environment; we don’t know if your drives will be attached directly to the server, through a Host Bus Adapter or a SAS/NAS module; additionally, RAID configuration depends of a series of factors and the decision on if your system will run one RAID configuration in particular.
Please send us the details requested for analysis.
We will be awaiting for your reply.
Have a nice day
Santiago A.
Hi KMook1;
Greetings from Intel® SSD Communities.
This is a friendly reminder this discussion remains open, awaiting for your reply.
Have a nice day,
Santiago A.
Hello KMook1;
Since we have not received a response for our previous request, this topic is being closed
Feel free to get back to Intel® communities.
Have a nice day,
Santiago A.
