Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Size of SRT Cache
I have a 64GB SSD set up as an SRT cache. I'd like to use 50GB for SRT and 10GB as a normal partition (for temporary location for big 3D models). Intel software will let me chose the full drive or 18GB. How do a user selected size for the SRT?
Community Manager
Hi
Not really a response but maybe it helps - If you keep your 3D models on the main HDD and access them frequently, they are more probable to be found on the SSD cache, which means the you will benefit from increased read speed. Also, if you use the Maximized mode, you will also benefit from increased write speed.
