Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Slow post with RAID0
Community Manager
Greetings,
I'm seeing a problem during boot-up on my http://www.notebookreview.com/coupons/sony.asp Sony Z which has 4 x 128GB SSD drives in RAID 0 via the Intel option ROM..
The machine appears to take longer to complete the POST process than it should. In the following video, you can see that after the Intel Option ROM display, there is an extended time where the cursor blinks. While this happens, the HDD indicator light stays lit.
http://www.youtube.com/watch?v=vTmjoZQM4dc YouTube - Sony Z VPCZ11FHX/XQ - Slow POST
Unfortunately, I didn't shoot any video of this specific machine before this issue began but I did shoot one on an "eval" VPCZ112GX/S I had previously.
http://www.youtube.com/watch?v=XSCFsgRV8fA YouTube - Sony Z post time with RAID shown and hidden.
This behavior started after I recreated the RAID volume.
Does anybody have and idea why this is happening?
MBall5
New Contributor II
Hello, it is hard to say if your Solid State Drive is cause of this slow boot using raid.
I suggest you to install the latest version of your BIOS and latest RAID controller.
If the issue persists I recommend you to contact the system manufacturer to see if they have any suggestion about this issue.
