Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Slow write on Probook 4540s with 530
MMach9
I brought a 530 (120GB) and its write speed is very poor. I can get only around 120MBps (read speed is OK, about 450MBps).
I use Probook 4540s with Windows 8.1 Update 1. (Everything is updated.)
Thank you for any advise.
Jose_H_Intel1
Hello Gerret, are you using the latest version of CrystalDiskMark?
There is a known problem with some antivirus or security software; try deactivating it before testing or use different benchmark software.
You may also want to check if the BIOS is setup in AHCI mode and if the partition in the Intel® SSD is aligned.
MMach9
Thanks for replay,
I deactivate my antivirus but it has no effect on write speed also AHCI was already activated.
I tried three different benchmark software always with same result.
Partitions on SSD seems to be OK. (Checked with "AOMEI Partition Assistant")
Jose_H_Intel1
Is this a SATA or mSATA Intel® SSD?
MMach9
It is SATA plug in intro "main" SATA connector.
Jose_H_Intel1
Try using http://www.iometer.org/doc/downloads.html Iometer with the built-in "access specifications" after changing the queue depth to 32 and the Transfer Request Size to 128KB.
