Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Space Issue With X25-M
I had a question concerning disk space when you have multiple drives installed. I have my X25-M 80GB for windows 7 64 bit and a few programs, in addition to a 400GB HDD for everything else. My question is, why does my SSD fill up when I install programs onto my HDD and how do I prevent it?
Thanks in advance
Tags (2)
Community Manager
If you install a programme on a different drive it can still impact the size of the windows folder. It might be worth checking your winsxs folder size, which seems to grow at an uncontrollable rate whenever the OS is changed. I recently reinstalled my OS (in the last two weeks) and the winsxs folder is already 6.23GB . I've seen it grow to 12GB before. The bad news is that there is little you can do to stop it growing. On Vista it was possible to clean useless files in the winsxs folder from previous service pack updates with a special hotfix app, but other than that deleting files is highly risky and unadvisable. On high capacity HDD drives the size of the winsxs is not a problem but with SSD the size of that folder is expensive and can soon make fitting the OS on a small capacity ssd a problem if you have a few other apps on it.
There is a bit about the winsxs file here:
http://www.winvistaclub.com/f16.html http://www.winvistaclub.com/f16.html
Although that link is for Vista it's more or less the same with Win 7.
Community Manager
Ah, darn. I'll have to look into this and see if there is anything I can do... Maybe transfer a game or two to the HDD to free up some space. Thanks a lot for the quick response.
