Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Step by Step Raid 0
Last year I did a raid0 setup on xp with 2 veloci raptors using the instructions from this site http://www.legitreviews.com/article/454/1/ http://www.legitreviews.com/article/454/1/. I will soon be trying Raid 0 with 2 x25 g2's on a Dell XPS 8000 i7860. Is there a site that has instructions for setting up raid 0 with ssd's. What steps would be different compared to raid 0 with regular drives? Thanks for any input.
DZand
Valued Contributor I
The procedure to create a RAID0 array with SSD's is the same as with "normal" SATA hdd's.
Community Manager
So this applies to Bios settings as well?
Community Manager
Hi there,
Yes, you got it right.
You definitely need to set the SATA to RAID in bios, then after the system restarts when the changes are applied, and if you are using Intel Matrix, you need to press Ctrl+i ge to the RAID bios and create the RAID 0 as you did before. It is exactly the same procedure, nothing has changed even if you are using SSDs.
Hope this is helpful to you.
Cheers.
