Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Still confused
My disk-configuration can't possibly be unusual, so I am wondering if I am stupid that doesn't understand how to upgrade the 160GB X25-M FW. Can someone look at my configuration and give me some helpful hints?
I have Windows 7 on a X25-M G2 160GB - not AHCI
Then I have two non-SSD disks in RAID (Intel Matrix Storage) for extra storage, i.e. my SSD is not in RAID.
I have heard that I have to disable my RAID even if it doesn't involve my SSD. Is that correct?
If so, at what point should I enable it again?
Are there other things to consider with this configuration?
Tags (1)
Community Manager
Community Manager
Thanks for you answer.
My BIOS says IDE, RAID or AHCI. The readme doesn't state exactly IDE, so I don't know if it is supported. I can't use RAID, and I installed Windows 7 with IDE set before I added the last two disks setting RAID.
Should I disconnect the RAID-disks, set AHCI, do the upgrade and set RAID again? Or will that f... up my Windows7?
Or should I try the same with IDE instead of AHCI?
Community Manager
The motherboard is an ASUS P6T if that is of importance...
