cancel
Showing results for
Search instead for
Did you mean:
TOOLBOX HELP
Esteemed Contributor III
Hi maybe someone could help me out I try running the toolbox on windows7 the drive shows up but when I try to click it it keeps refreshing and all the boxes to the left are grayed out.........any ideas.
10 REPLIES 10
Hi, Did you ever find a solution to this problem?
I had an older version of the tool box which used to say "problems connecting to drive" I've installed toolbox ver 2.0.1 today and now it shows the drives just fine, but every time I try and select it to pefrom a function, the list is just refreshes.
I've heard their might be issues with the with using NVIDIA nForce SATA drivers for the IDE controllers so I might try uninstalling those next....
I know when I tried to use the Toolbox 2.01 through a Silicon Image Sata port, the same thing happened. The toolbox saw the drive but when I clicked on it, an automatic refresh was done and I couldn't use any of the toolbox tools. When I plugged it into the motherboard Intel X58 Sata port, it worked fine. So I think Intel Toolbox only works with Intel Controllers and maybe a few others.
Also, note that to get the Secure Erase Feature to work, I also had to load the Intel RST drivers. Without RST drivers, I couldn't get past the ATA security step even though I was using the X58 Sata ports.
Good Luck.
Is your X58 board a Intel product , ASUS or Gigabyte ?? I've never tried to use the tool box on anything But intel boards and it has always worked??
I use the Intel SSD Toolbox on ASUS and Gigabyte motherboards, both with Intel chipsets and drivers of course, X58 and P43 in my case, but what matters is the Southbridge chip, which is the Intel ICH10R or ICH10, again in my case. All the other caveats apply, AHCI mode and the iaStor Intel driver.
Now that I think about it, will the Toolbox work with msahci?
yes.
