Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
The return policy is - questionable...
Having just lost my X25-M G2 160GB SSD boot-disk, I am trying to get a replacement unit.
But: Intel Europe demands that I fill out the following questionarie. Notice how several of the points are in fact impossible to do - if your machine can't boot, which is, i guess quite often the problem, when ones SSD dies.
Oh: and watch how the start of the document tells you to employ a trained technician! Real cute.
~~DukeP~~
<!--  /* Font Definitions */  @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 415 0;}  /* Style Definitions */  p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:EN-GB; mso-fareast-language:EN-GB;} p.MsoHeader, li.MsoHeader, div.MsoHeader {mso-style-unhide:no; mso-style-link:"Sidehoved Tegn"; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; tab-stops:center 216.0pt right 432.0pt; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:EN-GB; mso-fareast-language:EN-GB;} p.MsoFooter, li.MsoFooter, div.MsoFooter {mso-style-unhide:no; mso-style-link:"Sidefod Tegn"; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; tab-stops:center 216.0pt right 432.0pt; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:EN-GB; mso-fareast-language:EN-GB;} span.SidehovedTegn {mso-style-name:"Sidehoved Tegn"; mso-style-unhide:no; mso-style-locked:yes; mso-style-link:Sidehoved; mso-ansi-font-size:12.0pt; mso-bidi-font-size:12.0pt; mso-ansi-language:EN-GB; mso-fareast-language:EN-GB;} span.SidefodTegn {mso-style-name:"Sidefod Tegn"; mso-style-unhide:no; mso-style-locked:yes; mso-style-link:Sidefod; mso-ansi-font-size:12.0pt; mso-bidi-font-size:12.0pt; mso-ansi-language:EN-GB; mso-fareast-language:EN-GB;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt;} @page Section1 {size:595.3pt 841.9pt; margin:70.9pt 89.85pt 53.85pt 89.85pt; mso-header-margin:35.45pt; mso-footer-margin:35.45pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
ATTENTION
All system tests should be performed by a professional technician. Intel takes no responsibility for equipment damaged by inappropriate testing.
Please help us to help you. The more information you supply, the quicker we will be in identifying the issue.
Motherboard
Manufacturer:
Model:
AA number:
Revision:
<td style="width: 330.7pt; padding: 0cm 5.4pt; height: 14.2pt;" valign="top" width="44...
