Hello everyone,
I am using the Intel SSD Toolbox on my Vista Machine. As you probably know, MS Vista does not support the TRIM command, but the Intel SSD Toolbox allows to send the command even on a XP or Vista Machine. This function is called "Intel SSD Optimizer". A former version of the Toolbox worked well for over one year, but since I updated to version 3.0.3 I get an error message while using this SSD Optimizer function and I actually don't know how to cope with that. When I run the Intel SSD Optimizer, it stops frequently at 34% and the error message states: "Error: The Intel SSD Optimizer encountered an error (102). Reboot and try again." Well, that does not work, unfortunately. I don't even know, what that error code 102 actually means.
Suggestions I have already tried without success:
System configuration:
Intel Core i7 920
MSI X58 Platinum
MS Windows Vista x64 Business SP2
The SSD is connected to the Intel ICH10R SATA Controller.
SSD model: SSDSA2CW080G3
S/N: CVPR112407Z6080BGN
Firmware: 4PC10362
I would really appreciate any help. Maybe someone knows a download link of former versions of Intel SSD Toolbox as they are not available anymore on the official Intel Download website.
Thanks in advance.
I just had the same issue. Can you confirm your Microsoft.NET is running correctly?
I accidentally removed the Microsoft.NET 3.51 (Win7 x64 - Turn Windows features on or off ) and the error occured. Then I tried to reinstall Intel SSD Toolbox and I got the message Microsoft.NET 3.0 was missing. So I re-enabled it and no more errors for me. The optimzer works without problems now.
