Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Toolbox/TRIM Problem
Jump to solution
Can any one tell me why a series 335 240GB ssd takes 5 minutes to complete TRIM using the latest Toolbox? I'm using windows 7 and the Windows AHCI driver although I have used the Intel driver with the same result. Also when running TRIM the computer is useless until TRIM completes. The ssd passes all diagnostics and is aligned correctly. The drive is attached to the Intel SATA 3 port.
Walter
Jose_H_Intel1
Thank you for posting
The Intel® SSD Optimizer may take several minutes to complete depending on the SSD usage.
Jose_H_Intel1
