Community
cancel
Showing results for
Search instead for
Did you mean:
ARobe10
Toolbox with high contrast theme Windows 8.1 not usable
I have enabled high contrast theme for a user with poor eye sight, and have noticed several programs suffer invisible settings screen or worse.
For example here is Intel's SSD Toolbox 3.1.9.
High contrast default Windows 8.1 theme:
Generic Windows 8.1 theme:
Has anyone implemented a work around? As all I can think of is the three keys pressed together to switch off high contrast mode. But it's not an ideal solution for the user.
Jose_H_Intel1
Please allow us more time to investigate about this issue.
JSimo26
Was 6 years not enough time to investigate this? The issue is still present in v3.5.12:
