cancel
Showing results for
Search instead for
Did you mean:
Trim in RAID 0 using Intel RST on Windows 8 and 10
SHawk
New Contributor
I notice the following comment in the description of the Intel® Solid-State Drive Toolbox:
Optimize the performance of an Intel SSD in RAID 0 using Trim functionality Intel® Rapid Storage Technology (Intel® RST) 11.0 or greater.
NOTE: Trim on RAID 0 is not supported on Windows 8* or Windows Server 2012*
Is this a temporary situation? What about on Windows 10? I thought it was generally agreed that Trim was pretty important to keep write amplification down thus maintaining high performance and extending the lifetime?
3 REPLIES 3
jbenavides
Valued Contributor II
Hello Sam_hawker,
We understand the importance of TRIM and the benefits it provides to SSD's. The information currently available doesn't confirm if TRIM functionality is supported on RAID 0 on Windows 10* or not.
We will check further on this and will provide an update soon.
jbenavides
Hello Sam_hawker,
Trim for Intel® RST and RAID 0 was not supported at all under Windows 8 / 2012 due to some limitations with the Intel® RST driver.
This was fixed in Intel® RST driver release 14.6.0.1029, and the latest Intel® RST driver supports Trim for RAID 0 under Windows 8 / 8.1 / 10 and Windows Server 2012. This is natively supported by these OS versions and is normally enabled by default.
However, it is still not possible to run the Optimizer from Intel® SSD Toolbox with Intel® RST in RAID 0, under Windows* 8 / 8.1 / 10 and Windows* Server 2012.
You can find some additional information about TRIM in the following advisory:
http://www.intel.com/support/ssdc/hpssd/sb/CS-031242.htm Intel® High Performance Solid-State Drives — What are the Advantages of TRIM and How Do I Use It With My SSD?
Thanks, that's great news.
