Community
cancel
Showing results for
Search instead for
Did you mean:
BC4
Trouble with intel 750 SSD
Hello folks,
I downloaded the NVMe driver 1.3.0.1007 x32-x64, run the setup successfully and rebooted, but in Intel solid state drive toolbox it doesn't appear to have registered the change. it continues to display "Standard NVM Express controller ver 10.0.10240.16431"
Is there anything i can fix?
I'm currently running a Gigabyte z170x Gaming 7 motherboard and Windows 10
AP16
Valued Contributor III
How it looks in Windows Device Manager (Storage controller, not disk)?
BC4
AP16
Try to replace driver for controller using manual driver update option in device manager (needs to point to folder with unpacked 1.3.0.1007 x32-x64) .
BC4
Thank you that solves this issue!
Unfortunately I have another issue, which I've seen is somewhat recurring in the forum for while. It involves not being able to boot the ssd after system sleep with this current chip-set and brand of motherboard.
If i try following the guidelines for setting up the Bios by Intel, then the boot drive is not detected (Storage Boot Option --> UEFI ONLY), I've updated my Bios to run the most recent version (F5).
Now honestly it is not a deal-breaker for me, as my computer boots so fast. However i just wanted to see someone had managed to pinpoint the problem.
Thank you!
