Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Trying to install Win 7 on a HP 600 G1 PC with a Series 535 SSD (240 Gb drive 2.5" 6gb)installed Win 7 keeps asking for drivers.....? any suggestions, I cant find them anywhere
I need som assitance for obtaining the correct drivers for this drive so I can install Win 7 Pro 64bit. on the aforementioned PC.
Community Manager
Hello Joemama549,
We understand you cannot install the operating system Windows 7* due to some missing drivers and you have the Intel® SSD 535 series. We would like to let you know that for this drive, you don't need to install any driver as it should use the standard SATA driver.
We do suggest to check if the BIOS of your computer is updated as this might be the cause of your drive not being detected.
Also, check compatibility with HPE* to make sure the drive should work in this setup.
Regards.
Community Manager
Hello Joemama549,
We are following up this thread and we would like to know if you require any further assistance. We will be waiting for your response.
NC
