I just purchased a P3600 and installed in in a supermicro X10SRW-F system board with the latest bios. I installed Server 2012R2 in the P3600 and had it booting fine with the firmware it came with., I then installed the Data Center Tool 2.2.0 and performed the steps to update the firmware which it stated completed successfully. After the update I rebooted the system and now it will not boot to the P3600. So I installed it into a system that already has a boot drive to verify the P3600 was still accessible and it appears to still have all it's data it just refuses to boot to it.
Thoughts on what to try from here?
Steve
Here is the idct show -intelssd
- IntelSSD Index 0 -
Bootloader: 8B1B012D
DevicePath: \\\\.\\PHYSICALDRIVE2
DeviceStatus: Healthy
Firmware: 8DV10130
FirmwareUpdateAvailable: Firmware is up to date as of this tool release.
Index: 0
ProductFamily: Intel SSD DC P3600 Series
ModelNumber: INTEL SSDPEDME012T4
SerialNumber: CVMD4343007Q1P2CGN
Steveme,
Can you let us know if you receive any error massages or error codes when you try to boot it ?
I Don't receive any errors. It simply skips the Uefi shell instead of booting to the P3600.
Can you list out all the entries in the BIOS boot order?
Is there a "Windows Boot Manager" listed in the BIOS boot order?
With the current settings it was working until I installed the new firmware.
Hello Steveme,
We wonder if reinstalling Windows* would be an option for you?
*Please make sure you backed up all relevant information before this procedure and then restore it.
I changed the bois boot to both Legacy and dual and neither helped. I then reinstalled windows and the system won't boot to the drive to complete the installation. At no point during the boot sequence do I receive an error it simply doesn't boot. Is there a way to reload the firmware that came with the drive?
Hello steveme,
Please check your private messages.
