Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Unable to format intel x25-M SSD using HDDERASE 3.3 or 4 on ASUS P7P55D mobo
Community Manager
I am trying to format my SSD using HDDERASE 3.3 or 4 and it just sits there. I am booting form CDROM using HIREN 11.0. I changed BIOS setup to IDE from AHCI. Please help. I am stuck.
Community Manager
You can try using SSD toolbox 2.0, Intel has included secure erase in this newer version
Community Manager
I got it done using Win7 CD. It is running. I have another question for you, DO you know any tool that can show my SDD and SATA 3 HDD data transfer rate ? Also how doI know if TRIM is working ?
Community Manager
No idea what tool can show ssd and sata3.. and don't know if there is a software that can specifically tell if trim is enabled
There is an approach to check if trim is working.. can make use of disk defragmenter ->configure schedule->select disk
check if the ssd is detected in the list, if it is not found in the list then it means it will not be defragmented, which means it is detected as SSD
and implicitly means that trim is enabled.
Another way is through the help of ssdtoolbox, it has an optimization option which is to enable trim.
maybe others got better input to share
