Community
cancel
Showing results for
Search instead for
Did you mean:
DEngl6
Unable to upgrade my firmware for Intel 600P Series 128GB M.2 SSD
Run inside NUC6i3SYK Bios SYSKLi35.86A.0057.2017.0119.1758
Update using SSD Firmware Update Tool is missing Kernel module i915 and X11 will not start.
Community Manager
Hello Dave.English
We understand that you're experiencing some problems while trying to update to the latest firmware for your Intel® SSD 600p Series using our Firmware Update Tool.
If you're using Windows*, please download and install our latest Intel® SSD Toolbox. You should be able to update your firmware using this tool.
- Ihttps://downloadcenter.intel.com/download/26574?v=t ntel® SSD Toolbox Version 3.4.0 (latest).
- http://www.intel.com/content/www/us/en/support/solid-state-drives/000006345.html Intel® SSD Toolbox User Guide (Page 27-28).
Please post your results, or let us know if you experience issues with this method as well.
Carlos A.
DEngl6
We are don't use windows at all, we are all unix / linux in our corp.
Community Manager
Hello Dave.English,
Do you have any different model NUCs, or non-NUC systems capable of supporting the 600p Series that you could use to try and run the Firmware Update Tool in as a workaround?
If not, please switch your BIOS to Legacy Mode and disable http://www.intel.com/content/www/us/en/support/boards-and-kits/000006699.html Fast Boot, then try to run the Firmware Update Tool again.
If neither of these options work, please let us know.
Carlos A.
DEngl6
That's not the issue X11 will not start with the Firmware upgrade tool, Update using SSD Firmware Update Tool is missing Kernel module i915 and X11 will not start.
Community Manager
Hello Dave.English,
We have received similar reports in other OEM platforms. We understand your issue, but were hoping you were able to run the tool on another computer so that it may be used to update the firmware on your drives.
Since this is not possible, we'll need to reach out to our additional resources in order to find alternate troubleshooting steps, please keep monitoring this thread.
Carlos A.
Community Manager
Hello Dave.English,
We're still researching this issue with our additional resources.
In the meantime, you may find the workaround shared by user @mikemurphycs on a similar thread to be helpful: /message/459794# 459794 https://communities.intel.com/message/459794# 459794
Please proceed with caution and make sure to back up any important data before attempting this troubleshooting. Keep in mind that this is not an official fix and has not been tested by us.
If you're unable to use these steps, or it doesn't work for you, please let us know.
Carlos A.
Community Manager
Hi Dave.English,
We would like to check if you were able to follow the instructions on the previous post?
Also, we'd like to let you know that we'll be releasing a new update for the FUT.
Nestor C
Community Manager
Hello Dave.English,
We're glad to inform you that a new Firmware Update Tool has been released. This new version should resolve your issues booting to the tool.
Please try this download and let us know if your issue has been resolved.
- https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool Intel® SSD Firmware Update Tool Version 2.2.0
Carlos A.
