Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Uninstalling Intel Toolbox problem
Had installed 3.0 and tried to uninstall it and got error saying Win64 not supported so I installed 3.01 over top with no problem but I tried uninstalling to see if I got the error and I did. I did not have problems removing version 2. This started with 3.0.
Tags (1)
JAMES_J_Intel
I am running Win7/64 bit and the Toolbox 3.0 unistalled with no problem via Control Panel/Program and Features/Uninstall a Program.
How are you doing your uninstall?
Community Manager
I am running win7 64bit and tried from program and features to remove it. I saw on the internet some other people had problems. This is strange.
Community Manager
I am running W7 32bit.
I have no problems installing and uninstalling the Intel SSD Toolbox 3.0.1
Community Manager
Here is the error message,
Community Manager
I had the same problem (Win 7 64 Prof).
The uninstaller is a Java Applet. It has got a bug. If you have both Java 32 & Java 64 (Win XP 64 / Vista 64 / Win 7 64) the uninstaller tries to use JAVA 64 --> The Win 64 error message.
Workaround: Uninstall all Java 64 versions and let only Java 32 on your machine.
Uninstall Intel Toolbox --> Works without Problem.
Then you can install Java 64 an the Intel Toolbox.
Community Manager
Thanks for the info.
Community Manager
I uninstalled Java 7 update1 64bit and was able to remove the Intel SSD Toolbox. Thanks for your help on this.
Community Manager
