Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Update 320-series firmware from USB-drive?
Hi, I want to update my 320-series drive with the new firmware, but I don't have a CD-drive , I usually install OS:es and stuff from a USB-drive. I tried to follow the guidelines in this post: /thread/8906 http://communities.intel.com/thread/8906
I Can't find the file config.sys even though I have hidden system files visible. I guess the guide is outdated, does anyone know how to do this with the new firmware?
Community Manager
Just create it or edit one from win98boot.zip
Community Manager
Ok, I Solved it and have now succesfully updated the firmware.
There was a hidden folder, [boot], on the ISO that didn't show up when I mounted it in Daemon tools, instead I extracted it with 7-zip and found a new image that contained the files described in step C and I in the guide I mentioned (/thread/8906 http://communities.intel.com/thread/8906).
I completely replaced the contents of config.sys with the lines in step C
