Community
cancel
Showing results for
Search instead for
Did you mean:
CWalk4
Upgrade options for 80GB SDD
I have an 80GB Intel SSD in a Lenovo T410. (SSDSA2M080G2LE) and plan to swap it up to a SSDSC2BW120A4K5 or SSDSC2BW120A401. 120GB drive. Is this a straight swap scenario in terms of the physical sizes and connectors??
Obviously the data migration will be another issue..
Jose_H_Intel1
The difference between them in terms of size is that the Intel® SSDSA2M080G2LE is 9.5mm while the other two are 7mm. The physical SATA connection is the same.
We recommend you checking with the system manufacturer for a list of validated SSD models.
CWalk4
Thanks! Actually took the plunge and bought the 120. Did the simple Win 7 image backup and restore method and worked perfectly . Couldn't believe it was do easy. Created a D: drive with the extra space and my problem is solved . New drive also smokes the old one speed wise.
