cancel
Showing results for
Search instead for
Did you mean:
User Guide for Solid State Drive Data Center Tool 3.0.0 is missing
GJago
New Contributor II
In contrast to the statement https://downloadcenter.intel.com/download/23931 there "The DCT User Guide is included in both of the downloadable ZIP files [...]" I can't find the Data Center Tool User Guide in any of the three zip files.
7 REPLIES 7
ASouz7
Valued Contributor
Georg,
Is there any particular piece of information you are looking for regarding this tool?
VBela
New Contributor
I am here for the exact same reason as the OP.
Trying to determine how to run the Data Center Tool on my ESXi host and I have no idea how to do this. It is not documented - as far as I can tell.
I see that Windows and Linux it is done via the command line, no mention of VMware.
There is zero mention of how to run this on my VMware ESXi host. I was able to install the tool using the esxcli install vib, but after that - I was left on my own to figure out the rest.
It is not very intuitive nor do I immediately know how to get this running on my ESXi 5.5 host.
This tool needs documentation desperately and relatively fast.
Cheers,
V
GJago
New Contributor II
The syntax using isdct.exe has changed, Until now I was able to query the temperatures of my SSDs (Intel SSD DC S3500 Series) using
isdct.exe show -display raw -sensor ID=C2
resulting in
- BTWL4200007H480QGN.C2 -
raw: 34
- PHWL429200FB480QGN.C2 -
raw: 36
Now I'm getting
Syntax Error: Invalid command. Error at or around '='.
Did you mean:
show [-help|-h] [-display|-d (Property1,...)] [-all|-a] [-output|-o (text|nvmxml|json)] -sensor [-intelssd [(Index|SerialNumber)]]
instead.
I'm using Windows 7 Ultimate x64 SP1.
VBela
New Contributor
Not sure if this helps or not
isdct show -sensor | grep Temperature
OR
isdct show -sensor -intelssd | grep Temperature
OR
isdct show -sensor -intelssd 0 | grep Temperature
But, yes - an updated User Guide is a required.
P.S. Sorry to have hi-jacked your thread with my blurb.
