Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Using Toolbox on X-18 G1 Drive
Hello, I have an X-18 SSD model SSDSA1MH1601HP 1.8". Can I use the SSD toolbox on this drive? Do I need to flash the firmware to G2 and can this be done on this drive? Will the toolbox optimizer (manual trim) work on a G1?
Thank you
Mitch
RGiff
Honored Contributor I
The tool Box will only work on 32Nm drives.
Community Manager
This drive is not a 34 nm drive and, thus, the toolbox will not work?
Mitch
mmokk
New Contributor II
the toolbox will work, the optimizer will not.
RGiff
You might want to check with INTEL if a firmware update would Help??
mmokk
New Contributor II
would help what? intel g1 drives do not support trim, so the optimizer is disabled in the toolbox.
Community Manager
OK, so if I correctly understand this, no G1 drive will support trim - either through W7 trim command or with toolbox optimizer utility. Updating the firmware will not change this. Correct?
Mitch
Community Manager
Unfortunately no. You should however make sure you are using the most up to date firmware for the G1 drives.
Community Manager
Will the toolbox secure erase work on this drive and can this be used to periodically restore performance?
Mitch
mmokk
New Contributor II
i don't see any reason why the secure erase function in the toolbox would not work on a g1 (other secure erase utilities do work), and there's nothing in the documentation saying it wouldn't work, but i have not tried this myself.
if you notice performance degrading severely, then yes, a secure erase will restore it to 'factory fresh' performance. however, i have a bunch of g1's that have had terabytes of data written to them and never noticed performance degrading to the point where i needed to do a secure erase. but then again, i use these drives in desktops, i don't sit around with a stopwatch timing everything, and i don't hammer them with benchmarks. ymmv.
if you just bought this drive secondhand and are unsure of how it was (ab)used previously, then you may want to do a secure erase to start off on a clean slate.
