Community
cancel
Showing results for
Search instead for
Did you mean:
MBurk1
Using a Intel 510 120GB SSD with an Azzio 3.5" / 2.5" Docking Station
I recently won an Intel 510 120GB SSD. I currently have a Sony Vaio VGN-NS290J Laptop with an Azzio 3.5" / 2.5" Docking Station Attached. Can I run the new SSD with the docking Station by swaping my Terrabyte drive w/ the new SSD? You can email me your replies to mailto:cio@transatlanticcreations.com cio@transatlanticcreations.com.
Thank You,
Mark E. Burkhardt
Tags (1)
Community Manager
Yes, you can run a SSD in a docking station....
However:
1) Is this a USB 2.0, USB 3.0, or eSATA dock? If it is USB 2.0, there is no point since a HDD already saturates the connection.
2) If it is USB, the Intel SSD Toolbox will probably not work on the drive.
3) There will be no TRIM support (used to maintain the SSD performance over time)
Community Manager
This is a USB 2.0. Do I need an eSATA Docking Station?
Community Manager
Mark... for clarity, do you plan on placing your SSD or HDD in the dock?
Community Manager
Both. I currently have a laptop. Once I move, I will be building a new desktop.
Community Manager
Hello I just bought an Intel 120g 320 series SSD im using a labtop and im wanting to use the USB connectors instead of taking apart the computer and installing it but every time I connect it I dont know if its working or not and how do I make it my main drive? Im on Windows 7
Community Manager
If you want to boot from thois drive than set it as your boot drive in BIOS - Boot from USB
