Community
cancel
Showing results for
Search instead for
Did you mean:
DRobi14
Very slow write speed on SSD S3520
I have experienced horribly slow write performance on both my S3520 240GB drives on Windows 7, and would like some guidance.
The details:
I have 4 Intel SSDs : 2 x 530 Series (SSDSC2BW120A4 and SSDSC2BW240A4), and 2 x S3520 240GB (SSDSC2BB240G7). I have the same very disparate performance with both pairs. In addition, I have 3rd S3520 in the field with the same problem.
The pair I will highlight is as follows:
530 Series 120GB
F/W version : DC32
S/N: PHD A41 660 0Z8 120 7GN
DC S3520 240GB
F/W version : N2011021
S/N: BTD V72 750 FRY 240 AGN
The problem: I have a proprietary OS running on a Pentium server box, which has its own driver to talk to these SSDs in IDE mode. The 530 performs very well, in line with benchmark data I can find on the Web. The S3520 performs well also, except In certain cases, where its average sector write time is 26x (yes, 26) that of the 530. We have managed to produce a specific test case where we write 15,634 single sectors of a 13MB file, with specific content in each sector, and the same non-consecutive order of disk addresses being written. The average write time for sector writes to the 520 is 0.06ms, and the average write time for the S3520 is 1.56ms.
At first we thought there must be some compatibility problem between our disk driver and this specific drive.
But I have constructed a Windows program which writes these same sectors to a second pair of drives, in the same order, on Windows 7 (using FILE_FLAG_NO_BUFFERING).
The result is the same: < 1 sec to write the 15,634 sectors on the 530, and > 20 sec on the S3520.
I can only conclude that the S3520 has some severe firmware problem which makes it sensitive to the content (and/or the order) of certain data being written.
Does anyone have any experience with similar problems here?
Tags (1)
Community Manager
Hello DLRobinson,
We understand that you're experiencing slow write speed on three of your Intel® SSD DC S3520 Series.
In order to better assist you, we would like to take a better look at your system and SSDs details:
- Please download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility on the Windows* based system, with at least one of the Intel® SSD DC S3520 and 530 Series plugged. Select scan for "everything" then save the file to your computer.
- For specific SSD information, please download and run https://downloadcenter.intel.com/download/27130?v=t Intel® Solid State Drive Toolbox. Select the SSD and click on "Export" to get the S.M.A.R.T. details log. Do the same for both your Intel® SSD DC S3520 and 530 Series.
- Additionally, run a quick https://crystalmark.info/download/index-e.html CrystalDiskMark* benchmark for both drives and take screenshots of the results.
NOTE: Links to third party sites are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Please attach the resulting files to your next reply. To enable attachments, select the option to "use advanced editor" while replying.
Eugenio F.
DRobi14
Eugenio,
I have attached the info you requested. Each item is labelled by "S3520" for the 240GB S3520, or "530" for the 120GB 530 series.
regards
Dave Robinson
Community Manager
Hello DLRobinson,
Thanks for sharing the requested logs and screenshots.
Based on the system specifications, the benchmark results for your Intel® SSD DC S3520 Series are optimal. The S.M.A.R.T. logs show the drives are in perfect health as well.
Regarding the firmware, there haven't been any reports on major bugs for the latest Intel® SSD DC S3520 Series release (N2010121).
How exactly did you notice the slow write speed while the drives are in production?
Eugenio F.
DRobi14
Eugenio,
There is no question that the S3520, with the firmware version you see in my Intel Solid State Drive Toolbox report, performs very poorly with certain types of writes - either the data or the ordering or both.
We noticed the slow write speed when performing a certain type of operation in our OS. The operation is a common database maintenance task that our customers run frequently. The last phase of the operation rewrites the file of database indices - mostly binary data - the last part of this writes the file to disk one sector at a time and not in sector order. On regular non-SSD drives this operation, for average 5GB files, takes a fair while but is not unreasonable. On the 530 series SSD it takes very little time, but on the S3520 it takes literally hours - totally unacceptable.
As I explained in my original post, we have taken a small sample index file from our OS and constructed a test case that runs in Windows 7. It writes 15,000-odd sectors not in sector order and produces the same results, namely that the for the 530 disk it runs in < 1 second, but on the S3520 it takes over 20 seconds. This is reliable and repeatable EVERY time.
I have attached a copy of the test case for you to run and demonstrate the problem. Here are the details:
  • FD32.EXE is the test program. Put it in a directory together with its two data files.
  • You will need to turn off DATA EXECUTION PREVENTION for FD32.EXE, as it uses an old copy of the Borland runtime libraries which executes in its data.
  • The two input data files are TWO20.DAT and TWO20.CSV.
  • The program writes a temp file named TWO20.TMP to the location specified on the command line - see the BAT files.
  • Put at least one 530 (or equivalent) and S3520 SSD on the system.
  • In the BAT file TEST530.BAT, replace the 2 instances of the string "G:\" with "X:\", where X is the drive letter of the 530 SSD disk.
  • In the BAT file TESTS3520.BAT, replace the 2 instances of the string "E:\" with "X:\", where X is the drive letter of the S3520 SSD disk.
  • Run each BAT file and time the interval between the "Start" and "Done" messages printed by the program.
  • You will find this program takes over 20 times longer to build the file on the S3520 than it does on the 530.
Please let me know if you have any questions.
regards
Dave
Community Manager
Hello DLRobinson,
I was reviewing this post with a higher level technician and we're trying to reproduce the issue as per your indications.
Just for testing purposes, would it be possible to run a similar test on a different and newer operating system intended for server applications such as Windows* Server 2012 R2 or Windows* Server 2016 while we work on this?
Eugenio F.
DRobi14
Eugenio,
Sorry, I don't have any active non-virtual Windows Server installations, and none at all of the 2012 or 2016 variety.
Also, I don't see how it would help you for me to run this test in that environment - the discrepancy between the 530 and the S3520 is plain to see in Windows 7.
Furthermore, the problem is not motherboard or CPU or OS dependent, since I can reproduce this behavior on 2 very different PCs with 2 very different OSes,
regards
Dave
Community Manager
Hello DLRobinson,
Thanks for you reply. We understand your concern, however we just want to discard the possibility of the slowdowns being caused by the SATA driver on those operating systems.
Since server versions are not option, could you run the test on a newer operating system such as Windows* 10?
Eugenio F.
DRobi14
Engenio,
Sorry, I can't run the test program on Windows 10 either - I do have a Windows 10 laptop but no way to install the SSDs in it.
But to your point about perhaps the slowdowns are caused by the disk driver - I can already demonstrate the problem on TWO different OSes (mine and Windows 7) with COMPLETELY different disk drivers (one written by Pebble Ridge Systems and one by Microsoft). It is unlikely in the extreme that both those disk drivers (A) work perfectly with the 530 series and (B) are responsible for the S3520 problem.
You should pursue the test case on Windows 7 with your internal firmware diagnostics, to find the cause of the problem.
regards
Dave
Community Manager
Hello DLRobinson,
We didn't have any luck reproducing the test, it was showing expected write/read speeds on Windows* 7.
As mentioned before, our engineers are requesting would really like to confirm if the issue happens on other operating system to confirm if the issue is related to the drive.
Please let us know if there's anything else we can do for you.
Eugenio F.
DRobi14
Your answer was a trifle ambiguous. You did say you tried an an S3520 in Windows 7 and saw normal write speeds. But you did not specify whether or not you tested it with the special test case which I supplied to you.
The reason I ask is this : I have tested my S3520 under Windows 7 with 5 different SSD benchmark tools and all of them say the drive performs with normal (excellent) write speeds. Only MY test case shows the problem - and bear in mind my test case shows normal write speeds on two other different SSDs on the same PC.
So there is definitely a problem with the drive.
Did you run my particular test case, or some other benchmark?
If you tried my test case, I suggest you have me ship my drive to you for testing.
thanks
Dave Robinson
Community Manager
Hello DLRobinson,
Please check your private messages.
Eugenio F.
DRobi14
Eugenio,
Regarding this case (# 03122905), I received the below e-mail from you on Dec 11th 2017.
I see the error that the support people got when they attempted to run my test case.
My apologies - I failed to test the package in a directory that contained nothing except my test tools, and so missed the fact that the test program requires a DLL.
I have attached the missing DLL.
Please ask the support engineers to re-run the test case with the DLL.
thank you
Dave Robinson
Hello David, Thanks for your patience. I have received updates from our highest tier of support regarding this case. They weren't able to replicate the test you indicated. It returned an error saying "nosnetnt.dll" file is missing. Regular benchmark tests on the Intel® SSD DC S3520 Series (using latest firmware N2010121) showed no problems on Windows* 7 Professional 64-bit. As mentioned before, there are no other reports of this problem, nor were we able to find any other issues. Are you using a standard Windows 7* build? Also, would it be possible to send the failing setup to them? That would be ideal for clean replication and triage. Best regards, Eugenio F.Intel Customer Support
Community Manager
Hello DLRobinson,
We have news regarding your request.
Our higher level technicians were able to reproduce the test just as you indicated. and the results are expected behavior.
Please bear in mind that https://www.intel.com/content/www/us/en/products/memory-storage/solid-state-drives/data-center-ssds.... Data Center drives should not be compared with https://www.intel.com/content/www/us/en/products/memory-storage/solid-state-drives/consumer-ssds.htm... Consumer SSD when talking about performance as these products are architect-ed differently with different capabilities and expected usages.
The performance shows as defined in the https://ark.intel.com/products/93012/Intel-SSD-DC-S3520-Series-240GB-2_5in-SATA-6Gbs-3D1-MLC Specifications for Intel® SSD DC S3520 with CrystalDiskMark*; if different tools are used to measure performance (than the ones we specify, usually CrystalDiskMark* and IOMeter*), it might be expected to get different results.
Eugenio F.
DRobi14
Eugenio,
Sorry for the delay in getting back to you.
I have received the e-mail/post you sent on Dec 19th 2017, reproduced below.
I do not understand what you said about the high level technicians reproducing the test I gave you, and that "the results are expected behavior".
What you say does not really answer the most important question, which is this...
When they ran my test case, what was the elapsed time for the test? Was it close to the 20 seconds I experienced on the DC S3520?
If so, then the device failing to meet its specifications, just as it does for me. The specs, located at the link you sent me below, calls for 16,000 IOPS. At that rate, my test case of 15,634 sectors should run in less than one second instead of the > 20 sec which I see.
regards
Dave Robinson
========= Reproduced post =========
Hello DLRobinson,
Eugenio F.
DRobi14
Eugenio,
Not certain I know how to read my private messages - how do I do that?
If by "private messages" you mean those sent to my profile e-mail address, mailto:dave@pebbleridge.com dave@pebbleridge.com, I'm getting messages there. But otherwise, please advise how to read "private messages".
thanks
Community Manager
Hi DLRobinson,
Thanks for the reply.
We would like to inform you that the Intel® SSD DC S3520 Series has lower stats for the Sequential Read and write than the Intel® SSD 530 Series.
You can check the comparison here: https://ark.intel.com/compare/75611,93008
The Intel® SSD DC S3520 has the following stats:
*Sequential Read (up to): 295 MB/s
*Sequential Write (up to): 250 MB/s
The Intel® SSD 530 Series has the following stats:
*Sequential Read (up to): 540 MB/s
*Sequential Write (up to): 480 MB/s
That is why you have slower write speeds with the Intel® SSD DC S3520. Please bear in mind that it is a Data Center SSD and it has higher endurance than the Intel® SSD 530 Series.
Junior M.
