Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
W7 detect my SSD as a SCSI disk device. How to change it to ATA device?
My configuration:
OS: W7 x64 Ult
MB: Gigabyte EX58-UD3R
SSD X25-M 80GB G2 plugged on the GSATA 2 connector of MB
What I tried:
  1. In bios setup: switch "Diseable" in AHCI mode => boot stop at DMI detection
  2. On motherboard move SSD from GSata 2 (GigabyteSATA) connector to Sata 2 connector (ICHR10) => Message: "bootmgr is missing
    1. To see what Crystaldiskinfo could say about my SSD => CrystaldiskInfo don't list my SSD!
    Tags (1)
    DZand
    Valued Contributor I
    You should connect the Intel SSD to the first Intel SATA port and not to any GIGABYTE (=JMicron) SATA port. After having done that, you should enter the BIOS and set the Intel SATA Controllers to "AHCI" Mode.
    If you still get the message "bootmgr is missing", just boot off the Win7 x64 DVD or USB Stick and let Windows Setup repair the MBR.
    Community Manager
    Thank you Fernando for your answer. I already tried to check AHCI in bios setup but the option "automatic repair for boot issue" doesn't repair succesfully the "bootmgr is missing" problem, so I'll try again with dos fixmbr command
    Community Manager
    Hello. See if the information in the following thread helps. I have an EVGA 790i mobo, and the solution was to change from the NVIDIA controller back to the "Standard" controller as in the thread below. Then my drive is seen by the tool.
    /message/78383# 78383 http://communities.intel.com/message/78383
    Best wishes/jim
    Community Manager
    Now, all is ok for my SSD . And I complete the Fernando answer by reporting that the problem of restarting after check AHCI in bios setup is caused by a Windows installation with IDE driver instead of AHCI driver. But the very simple solution is given by Microsoft Support for Vista as for Win7 here:
    http://support.microsoft.com/kb/922976/en http://support.microsoft.com/kb/922976/en
    or http://support.microsoft.com/kb/922976/fr http://support.microsoft.com/kb/922976/fr
    for french people like me . Big thanks also to this complet FAQ about Intel SSD's (in Fr) at: http://forum.hardware.fr/hfr/Hardware/HDD/topic-unique-intel-sujet_858306_1.htm# bas http://forum.hardware.fr/hfr/Hardware/HDD/topic-unique-intel-sujet_858306_1.htm# bas
    DZand
    This only happens, if you change the BIOS settings of the SATA ports from "IDE" to "AHCI" after the Win7 installation.
    If you do it before starting the OS installation, the in-box MS AHCI driver will automaticly be used by Windows 7 (no risk of any boot problems and no manual registry manipulation required).
    Community Manager
    Yes, exaclty. Thank you Fernando for having translated more clearly what I meant. My english is very rough...
