Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Want to align partition on 160GB SSD for XP... can't run Diskpar.exe
I used Diskpar.exe successfully a few months back, but when I try to run it now I just get a momentary flash... very short, can't see any text. Same result on all 5 computers I've tried. And, my "Diskpart" apparently doesn't have an "align" parameter, so that doesn't work either.
Any ideas of what to try next?
TIA
Community Manager
Have you read thread /thread/14108?tstart=0 Paragon Alignment Tool (PAT) ?
Remember:
Always clone or take a full backup of an HDD/SSD before running anything like PAT.
Since you mentioned XP, you also may be interested in thread /thread/14145?tstart=30 Easy way to Enable AHCI on XP running in IDE mode . Note that first post is garbled so start reading at corrected second post.
Community Manager
Thanks for the response.
Seems I encountered PAT a couple of days too late.. :>)
I believe my rig is already running in AHCI mode... won't boot if other is selected.
