Community
cancel
Showing results for
Search instead for
Did you mean:
MMokh4
We installed P4618 on our server. Is it normal that instead of 1 disk device with capacity 6.4TB, we see 2 devices with 3.2TB?
Jump to solution
Bootloader : 0163 DevicePath : /dev/nvme0n1 DeviceStatus : Healthy Firmware : VDV10160 FirmwareUpdateAvailable : Please contact your Intel representative about firmware update for this drive. Index : 0 ModelNumber : INTEL SSDPECKE064T8 ProductFamily : Intel SSD DC P4618 Series SerialNumber : PHLN920500046P4EGN-1Bootloader : 0163 DevicePath : /dev/nvme1n1 DeviceStatus : Healthy Firmware : VDV10160 FirmwareUpdateAvailable : Please contact your Intel representative about firmware update for this drive. Index : 1 ModelNumber : INTEL SSDPECKE064T8 ProductFamily : Intel SSD DC P4618 Series SerialNumber : PHLN920500046P4EGN-2
Esteban_C_Intel1
Hello MMokh4,
Yes, it's normal to see 2 devices of 3.2TB because this SSD has the particular feature of including 2 controllers. Each controller manages a half section of the SSD; hence it is shown as 2 separate drives. You can use the drive this way, or if you want to use it as one single drive with full capacity, a RAID 0 array must be set up.
In order to setup the RAID configuration you can use the Intel® Virtual RAID on CPU (Intel® VROC).
Esteban C
A Contingent Worker at Intel
Santiago_A_Intel
Hi MMokh4;
We have taken note of your issue; we will need to further investigate.
We will get back to you as soon as we can.
Have a nice day
Santiago A.
Esteban_C_Intel1
Hello MMokh4,
Esteban C
Esteban_C_Intel1
MMokh4,
This is a friendly reminder of the update done to this thread 3 days ago. I was also wondering if you had further questions.
Esteban C
Esteban_C_Intel1
MMokh4,
This is to verify if you had further questions or if the answer provided was clear.
Esteban C
