Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
What Features for the Intel Toolbox?
Intel does listen to our feedback so let's get heard! So what features would you like to see added or improved upon in the Intel Toolbox? Make sure to provide reasons as well!
So far, we have:
1) A benchmark to assist in determining nominal performance
2) TRIM, Driver, SATA Mode information
3) Offical performance tweak options (write caching)
4) Space reduction (Hibernation, System Restore, Paging File)
5) Links to suggested tweaks.
What else? These are up for discussion as well.
I'll maintain this and see what you guys demand.
Community Manager
Carried over from the FAQ thread:
Add feature to show if native trim support is being executed by the SSD
Add a feature to show if the drive is aligned
Add a feature that shows if the drive is in IDE or AHCI mode
Add a feature to identify the chipset type and driver
Add a feature to show if the drive is operating optimally
Add a feature to the system configuration tuner that automatically enables write caching if switched off.
Add optional advanced user features: Turn off the page file, Turn off hibernation, Turn off System Restore (and delete restore files)
Community Manager
New Toolbox Features:
Extensive help and/or tips via Internet links, that would contain the latest information on optimizing a PC for use with an SSD, any news or updates related to Intel SSD's, including problems and their resolutions. Any and all pertinent Intel SSD information available at a few clicks of the mouse. Reason: Optimizing information and instructions would allow the user to choose which ones they want to use, rather than simply performing all of them, or none, and avoid the cost of automated implementation of optimizations. Having general SSD optimization information available in an simply locatable area, while helping non-Intel SSD owners as well, would also bring them to the Intel web site and expose them to Intel products.
Option to set folders such as: Downloads, Temp(orary), both for Windows general use and for other software and hardware. Or simply instructions on how this is accomplished. Reason: Reduction of writes to SSD
A diagnostic analysis of impending or current performance problems with a SSD (ie, SSD usage nearing, at, or beyond capacity where performance may/will suffer.) Also, benchmark comparison of current vs previous test results that indicate a drop in performance and warn the user something happened to cause this since the last benchmark. Reason: Determine and solve problems before they become larger or an issue.
PS: Regarding an earlier suggestion post, all but the latest restore "points" can be deleted from the second tab of the Windows 7 Disk Cleanup utility.
Community Manager
Run as a service and minimize to notification area in taskbar.
I would like RST and Toolbox to be standalone software but an option to merge the running software into one icon in the notification area where by right clicking on the RST icon links to and opens Toolbox.
Community Manager
I believe the RST and SSD Toolbox teams are independent of each other. This means integration of them together is unlikely at this point in time.
Intel cannot implement options for 3rd party software (like Firefox or Photoshop) due to liability questions. Official options would also require Intel to be dependent on the 3rd party vendors in communicating changes. I don't think this will happen.... but a link to the communities suggesting performance instructions would work though.
The point where performance begins to suffer is subjective though. Someone doing intensive random writes will encounter issues before most users. However, I am advocating for an official Intel benchmark tool though. Most current benchmarks are really based around HDD testing.
Community Manager
I know thats not completely true as there is no way SSD toolbox could view SMART without the source code of the "iaStor.sys" driver.
Not asking to fully integrate it just a right click link to run it making less mess of listed icons and quicker access to Toolbox. Anyway it would have to run independently for non-Intel systems or those that like to run it independently as an option. If not then just Run as a service and minimize to notification area in taskbar will do.
Community Manager
I understand DuckieHo, the liability issue is one that interferes with many things, nothing can be done about it, except accept it.
Some of my suggestions are certainly stretches, and I'm struggling to find something useful, since redux took all the good ones...
Community Manager
Are you sure? The 3rd party party application HD Tune can read SMART values from HDDs running under the iaStor.sys driver as well.
I confirmed this yesterday while checking my home server HDDs. I connected each of them to my X58's ICH10R ports and I know I am running iaStor.sys because I have 3xHDDs in RAID0.
Community Manager
There is no way to select a SSD or HDD made up in the array in HD Tune as all you can select is the volume so unless your running windows RAID and not off the Intel RAID controller I see no way how you could view SMART in any other way with HD Turn. When I run HD Turn I can only select a volume with Health listed as blank/nothing.
And it has been a fact for some time that you can't view S.M.A.R.T. values of hard drive after setting up RAID.
http://www.intel.com/support/chipsets/imsm/sb/CS-015002.htm?wapkw=%28SMART+raid%29 http://www.intel.com/support/chipsets/imsm/sb/CS-015002.htm?wapkw=%28SMART+raid%29
Community Manager
Ahhh.... You had meant to say "I know thats not completely true as there is no way SSD toolbox could view SMART of an array member without the source code of the "iaStor.sys" driver."
That being said.... having the source code and collaborating are two different things.
Community Manager
And you confirmed that?
Community Manager
I am running 3xRAID0 Seagate 7200.10 500GB on a ICH10R (Asus P6T X58). Being in RAID, I must be using iaStor.sys.
I used HD Tune to check the SMART values of 6 HDDs pulled from my home server. I hotswapped each drive and checked their health. I'll get a driver + SMART screenshot up when I get home.
OT: One drive is power cycling and its warranty expired 35 days ago. The other one is out of reallocation sectors and it had just came back from RMA 3 months ago.... and is now out of warranty as well.
Community Manager
Yes but you said "HD Tune can read SMART values from HDDs running under the iaStor.sys driver as well." and that you "confirmed this" by saying "I know I am running iaStor.sys because I have 3xHDDs in RAID0" since we both know you can't do that with HD tune you could not of confirmed this in the first place for using HD tune to check SMART in your RAID0 yes?
Surely when you was running HD tune and Toolbox that "nope can't view SMART in my RAID0 with HD tune" and then "hey I can view the SMART of my drives in RAID0 cool".
Community Manager
There is some confusion here.... I am saying that you don't need the driver source code to view SMART values from a non-member disk. To view SMART values from members of an array is a different story. You would need the driver information to support that.
Here is the confirmation:
Community Manager
Yes confirmation very good it allows SMART to pass through "iaStor.sys" for a single drive we get it! Its the fact that Toolbox can view SMART in RAID being why I posted SSD toolbox couldn't view SMART without the source code of "iaStor.sys" in the first place or else why would I say Toolbox needed source code of "iaStor.sys" in the first place.
And yes by RAID I mean the drives in RAID not single drives and thats why Toolbox already can view all SMART for all drives in any config and HD tune can not.
Thats all and "iaStor.sys" is commonly known for it being a RAID driver.
Community Manager
The ability to update firmware from the Toolbox.
Community Manager
Hey, the holidays are over!
Given the current process, that would be fantastic, but the programmers are laughing and cursing at that one I bet.
