Community
cancel
Showing results for
Search instead for
Did you mean:
СКаль
What is S3110 SSDSC2KI010T801 1TB ?
Jump to solution
Hello. I want to purchase an S3110 SSDSC2KI010T801 1TB. However there is no information on this disk on the Intel website
https://www.citilink.ru/catalog/computers_and_notebooks/hdd/ssd_in/1145662/
Please provide information on this disk
BrusC_Intel
Hello, СКаль.
Thank you for the information.
The drive is must be OEM, that is the reason why the warranty information is not being displayed properly, warranty services are not provided for OEM drives, they only have warranty through the system manufacturer (OEM) or the place of purchase.
I will contact you privately to get a picture of the drive label so I can confirm.
Bruce C.
A Contingent Worker at Intel
BrusC_Intel
Hello, СКаль.
Good day,
Thank you for contacting Intel Community Support.
Please be aware that support is provided in english only and I will be using a translator to provide you with assistance.
Specifications for other drives from the same family can be found on the website:
Since the 1TB version is not listed, this could be related to the drive not being a regular production model, it could be OEM (specifically designed by Intel for a third-party for them to implement it in their own systems), an engineering sample or another type of release, like a direct substitute for another discontinued model for example .
My recommendation is to check the list "Intel® Authorized Distributors and Approved Suppliers" and filter by country, the distributors are able to provide you with mode guidance and details regarding available drives:
Bruce C.
СКаль
Hello, Bruce!
I bought this s3110 1TB drive. If I enter the serial number of my disk to check on the Intel website to verify the warranty, then the website tells me that it is a 545s model. Is that normal?результат проверки по sn.png
BrusC_Intel
Hello, СКаль.
Bruce C.
