Community
cancel
Showing results for
Search instead for
Did you mean:
__
What is the difference between SSDPE2MW012T4X1 and SSDPE2MW012T4M2
The ordering information for the SSD 750 references two different part numbers (SSDPE2MW012T4X1 and SSDPE2MW012T4M2) but it is not clear what distinguishes these items. What is the difference?
http://ark.intel.com/products/86741/Intel-SSD-750-Series-1_2TB-2_5in-PCIe-3_0-20nm-MLC# @ordering Intel® SSD 750 Series (1.2TB, 2.5in PCIe 3.0, 20nm, MLC) Product Specifications
Community Manager
Hello Aenagy,
We understand you'd like to know the differences between the two SKUs for the Intel® SSD 750 series.
For you to be aware the product code: SSDPE2MW012T4M2 is the one that includes the U.2 to M.2 cable, while the other code: SSDPE2MW012T4X1 includes the old U.2 cable.
Hope this information is useful, in any case, feel free to ask us any other doubts.
Nestor C
__
Does this mean that the connector on the HDD is U.2 for both kits?
Community Manager
Hi Aenagy,
The cable that was included before is an SFF-8639 connector, you can take a look http://www.intel.com/content/www/us/en/support/solid-state-drives/consumer-ssds/000005797.html here for a picture.
Now, the cable we used to send required your motherboard to accept the SFF 8643, mini-SAS HD connector. Some manufacturers also included a hyper kit, so you could install it properly.
For now, the cable that it is included is http://click.intel.com/u-2-to-m-2-ssd-cable-replacement-u-2-to-m-2-cable-for-intelr-ssd-750-series.h... this one
Nestor C
Community Manager
Hi Aenagy,
We are following up and we would like to know if you require further assistance. We'll be waiting for you.
Nestor C
__
I think I need to be more explicit about what I'm trying to do. If am configuring a system with a Gigabyte GA-X99-Designare EX system board (http://www.gigabyte.com/Motherboard/GA-X99-Designare-EX-rev-10# ov GA-X99-Designare EX (rev. 1.0) - GIGABYTE - Motherboard , Graphics Card , Laptop ,Tablet , Mini-PC , Server , PC Perip… ) which has two onboard U.2 interfaces (U2_32G_1 and U2_32G_2). I need to know which is the correct SSD 750 part number to plug into these ports.
See references to "U2_32G_1"/"U2_32G_2", especially page 28 of the manual (http://download.gigabyte.us/FileList/Manual/mb_manual_ga-x99-designare-ex_e.pdf http://download.gigabyte.us/FileList/Manual/mb_manual_ga-x99-designare-ex_e.pdf)
Community Manager
Hello Aenagy,
The system you are trying to put the SSD on is perfect for the SSD you have, as you noted there, it comes with two U.2 ports where you can easily just plug the cable and it will work fine.
The part number for this one is SSDPE2MW012T4X1, the good thing is that you don't need any extra hyper-kits or anything.
Nestor C
__
Nestor:
Thanks for your answer. I will mark your answer as correct once I receive my new PC. Hopefully soon.
Community Manager
Hi Aenagy,
We are glad we have this thread covered and answered. Feel free to select correct answer once you can.
Nestor C
