Community
cancel
Showing results for
Search instead for
Did you mean:
JBogg3
What is the maximum power consumption of the SSD 7600p when operating at maximum write and read speed?
Jump to solution
JosafathB_Intel
Hello JBogg3, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
AlHill
JosafathB_Intel
Hello JBogg3, Thank you for having contacted the Intel® Memory & Storage Support community. We will like to know if you have been able to review the information shared by the community. We will like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JBogg3
Hello all,
Yes I've checked that says 50 mW but I think that value is a typical value not at maximum speed data write/read transmission which is what I am intending to know.
Many thanks in advance.
JosafathB_Intel
Hello JBogg3, Thank you for your reply. We are going to be working on your inquiry. We will be contacting you back as soon as we have an update or in case that further information is required. Thank you for your patience and understanding. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello JBogg3, Thank you for your patience. The power consumption of this drive while active is 50mW, idle 25mW and Sleep is 3mW. We hope you find this information helpful. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello JBogg3, Thank you for contacting Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
