cancel
Showing results for
Search instead for
Did you mean:
What serial-number should I provide if I need warranty of 320 80G SSD?
Esteemed Contributor III
What serial-number should I provide to intel service staff if I need warranty of 320 80G SSD?
I am at U.S.A now.
5 REPLIES 5
JAMES_J_Intel
Contributor
The serial number is on the top left-hand corner of the SSD label. The first 4 characters are letters followed by 14 letters/numbers.
Example: ISN: CVGB955402MD040GGN.
Thank you for your answer!
Whether should I only provide "ISN"?The others SN like WWN PBA LBA SA etc ,does these SN also need to provide?
You will need to provide both the ISN number and the SA number. The SA number is located directly below the ISN number on the SSD label. The SA number starts with a letter that is followed by 5 digits and then a 3 digit dash number. Make sure you include the dash number. The other numbers on the SSD label are not required for a warranty replacement.
SA: E12345-001
Thank you very much!
