Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
What type of SATA does HP Envy M6 ae151dx have?
The laptop has a 1TB HDD 5400rpm.
Tags (1)
Highlighted
I checked the HP site for the chipset and sata information for your notebook. Seems like they deliberately avoid discussing those components.
I would contact HP support and ask them.
Doc
Highlighted
Community Manager
NeHCirE,
We always recommend for you to confirm compatibility with your system manufacturer.
It's also worth noting that SATA is backwards compatible. So if you install a newer SATA 3.0 (6Gb/S) drive on an older generation SATA port (1.x 1.5Gb/S, or 2.x 3Gb/S) it will simply function at the slower applicable speed.
Carlos A.
Highlighted
Community Manager
This is crazy: (Here's what each one said.)
Kingston - I have SATA III
Crucial - I have SATA II (Crucial System Spec Scanner said 6 Gb/s {SATA III}.)
SanDisk - I have SATA II
HP - M.2 (When I asked which SATA it was, {I,II,III}.)
HWiNFO64 - I have 6 Gb/s {SATA III} (Not sure if this is reliable.)
Highlighted
Community Manager
NeHCirE,
Unfortunately all we can do here is help you make an educated guess. Looking at all of their responses it's safe to say that your laptop uses SATA 3 or 2. Either way, you should have no issues with a brand new SSD, since SATA is backwards compatible.
As for the M.2 response, they're either dead wrong, or your laptop also has an expansion slot. M.2 is a form factor, and for storage there are no M.2 hard drives (so that's not where your 1TB HDD is currently installed), only solid state drives. So perhaps this slot is meant for a secondary M.2 SSD.
2.5" vs M.2 form factors:
We hope this helps.
Carlos A.
Highlighted
Community Manager
NeHCirE,
We're following up on your thread since we haven't heard back from you.
Please let us know if you require further assistance.
Carlos A.
Highlighted
Community Manager
Regarding Intel Securities, McAfee, what are the differences between, Internet Security, Antivirus, and Total Protection? Thanks.
Highlighted
There is no support for these products here. Contact Intel Security at the following link: http://www.mcafee.com/us/about/contact-us.aspx Contact Us | Intel Security
Doc
Highlighted
Community Manager
Thanks, Al Hill.
