Community
cancel
Showing results for
Search instead for
Did you mean:
GLi29
Where can I get Intel SSD DC P4600 product specification?
Jump to solution
DiegoV_Intel
Hi Guofeng,
Please see my answers below, I hope I covered everything you want to know.
Q1, the SSD controller writes data to all blocks. After long period writes, the write cycles of all cells are almost same. This is a pure hardware character. Am I right?
That’s correct. After long period writes, the write cycles of all cells should be around the same. This is a hardware feature, but also the firmware in the drive manages how the data is written into these cells.
Q2, can I use the wear_leveling of nvme smart log to determine if a ssd is close to the lifetime?
We recommend to use the Intel® SSD Data Center Tool (DCT) to monitor the SSD health and lifetime. Actually, this tool includes a feature called “Endurance Analyzer” which calculates the life expectancy of the drive based on a user workload. Please check additional details in the following User Guide: https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/Intel_SSD_DCT_3_0_x_Use...
The wear_leveling value of the NVMe* Smart Log shows how much of the rated cell life was used. So considering this information, it may work to determine if the SSD is close to the lifetime, however the recommended tool for this purpose is the Intel® SSD Data Center Tool.
Q3, P4600 Endurance Rating is 23.23 PBW. (23.23 PBW / Capacity) is equal to the max write cycles. Am I right?
The 23.23 PBW value means that you can write 23.23 Petabytes (PB) into the drive before it should be replaced. Since the drive has a warranty period of 5 years, that means that 23.23 PB / (5 years x 365 days) is equal to 12.728 TB per day (approx.). That means that you can write up to 12.7 TB per day during 5 years before the SSD should be replaced. That is almost 3 Drive Writes Per Day (DWPD) if you are using the 4.0 TB capacity drive. The value of 3 DWPD means that you can write 3 times the drive’s capacity each day.
I hope this information clarifies your concerns. If there is anything else I can help you with, feel free to ask.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi GLi29,
Thank you for posting in the Intel® communities.
Unfortunately, the Product Specification document is not available to public. However, I would like to know which information you need about the drive, or the reason why you need this document.
I’ll be waiting for your response.
Have a nice day.
Diego V.
n_scott_pearson
Super User Retired Employee
GLi29
I need some information about performance and reliability, especially endurance.
I find the product spec of 3500 - https://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-s3500-spe...
I am using it as reference.
Here are my initial questions:
probe198:/ # nvme intel smart-log-add /dev/nvme0n1 Additional Smart Log for NVME device:nvme0n1 namespace-id:ffffffff key normalized raw program_fail_count : 100% 44 erase_fail_count : 100% 0 wear_leveling : 98% min: 102, max: 138, avg: 124 end_to_end_error_detection_count: 100% 0 crc_error_count : 100% 0 timed_workload_media_wear : 100% 63.999% timed_workload_host_reads : 100% 65535% timed_workload_timer : 100% 65535 min thermal_throttle_status : 100% 0%, cnt: 0 retry_buffer_overflow_count : 100% 0 pll_lock_loss_count : 100% 0 nand_bytes_written : 100% sectors: 25044816 host_bytes_written : 100% sectors: 22662463
Thanks, Guofeng
DiegoV_Intel
Hi Guofeng,
Have a nice day.
Diego V.
GLi29
Hi Diego,
Thanks for your answer.
Your answers are very clear.
Much appreciate!
Thanks, Guofeng
n_scott_pearson
Good answers Diego!
GLi29
Also, thanks for your support!
You can close tthis ticket for now.
If I have more questions, I will create a new one.
Thanks, Guofeng
DiegoV_Intel
Hi Guofeng,
I’m glad to know you found my answers useful.
If you ever have a new issue or concern, please feel free to open a new thread.
Have a nice day.
Diego V.
