Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Why is my X25-V so slow?
I had been looking at benchmarks before purchasing this drive and everyones seem to be a hell of a lot higher than mine:
I'm running windows 7 and the SSD toolbox was run just prior to running this test.
Community Manager
The common thing I see in similar situations such as this is that many new ssd users have simply cloned and reinstalled the previous setup. I always advise a clean install to get rid of ols settings which may limit your performance such as trialware, bloatware and original manufacturer registry settings that were there for their own system setup.
Community Manager
4k and latency seems a little out of whack.. what's your subsystem? notebook/desktop - intel config, southbridge etc.
if desktop, first try another SATA cable.
Community Manager
I am on a http://www.clevo.com.tw/en/products/prodinfo_2.asp?productid=177 Clevo X8100 and I installed Win 7 myself on a clean drive, no cloning
Community Manager
Do you have disk caching enabled? In device manager, click on the disk drives then right click on the SSD , choose properties, then policies.
jj
Community Manager
Yes I do... Should it be disabled? With it off my speeds were much much lower.....
Community Manager
No, it should be enabled (boxes checked). You're scores looked like mine when I didn't have mine checked.
Community Manager
No, they were enabled....
Community Manager
No other suggestions guys?
Community Manager
Do you have the ability to take the SSD out and benchmark it in a desktop system?
PJack1
Well that looks better than my benchmark, then again mine is installed in a Netbook (Lenovo S10-2)
