Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Why is only 223.57 GB seen of my 240 GB SSD
DWall9
I am about to install an OS on to this series 530 240GB SSD. I first look at it in a host Win 7 environment via Disk management. Disk Management states only 223.57 GB is unallocated. 240 - 223.57 = 16.43 GB unaccounted for. That is too large of an overhead wouldn't you agree? Is it possible to reclaim most of that 16.43 GB and how do you?
Also, since I am installing a fresh OS onto the SSD is there any prep work I need to do to the SSD?
glussier
Same reason why you are not getting 1TB on your C: drive. Hard-drive manufacturer calculator KB, MB, GB etc with a 1000 factor instead of 1024 like normally used. So, no, you can't get more from your 240GB drive.
