cancel
Showing results for
Search instead for
Did you mean:
Why the power consumption of p3608 is too large?
SHibi
New Contributor
The power of p3608 is 40W at active state by the following document.
https://www-ssl.intel.com/content/www/jp/ja/solid-state-drives/ssd-dc-p3608-spec.html https://www-ssl.intel.com/content/www/jp/ja/solid-state-drives/ssd-dc-p3608-spec.html
The power of pro 6000p is 100mW at active state by the following document.
https://www-ssl.intel.com/content/www/jp/ja/solid-state-drives/ssd-pro-6000p-brief.html https://www-ssl.intel.com/content/www/jp/ja/solid-state-drives/ssd-pro-6000p-brief.html
Why the power consumption of p3608 is significantly overlarge compared to the performance difference between p3608 and 6000p?
4 REPLIES 4
Esteemed Contributor III
Hello So_Hibino,
Thanks for posting in our forum.Regarding your question, first of all, the Intel® SSD DC P3608 is a Data Center drive for high-end use like servers.Also, this drive uses two controllers, it is just like having 2 SSDs.Please check http://ark.intel.com/compare/88731,94932 this link with a comparison of both drives, in there you will also see that the Data Center drive comes with enhanced power-loss data protection."Enhanced Power Loss Data Protection prepares the SSD for unexpected system power loss by minimizing data in transition in temporary buffers, and uses on-board power-loss protection capacitance to provide enough energy for the SSD firmware to move data from the transfer buffer and other temporary buffers to the NAND, thus protecting the system and user data."All these reasons apply to the power consumption for each drive.Please let us know if you have any other question.Regards,Nestor C
Hello So_Hibino,
We would like to know if you require further assistance about this thread. We'll be waiting for your response.Regards,Nestor C
SHibi
New Contributor
thanks you for giving your good help!
Hi So_Hibino,
You are very welcome. Hope you have a nice week.Regards,Nestor C
