cancel
Showing results for
Search instead for
Did you mean:
Will Toolbox work without AHCI?
Esteemed Contributor III
I've just installed an X-25V (FW: 02HB) with Win7x64 on a system with an Nvidia 680i SLI MoBo Chipset. This is an older Dell XPS 720 with the awful Dell BIOS which won't let me set AHCI/IDE within BIOS.
The Nvidia Nforce Storage Controller takes over as the default Storage Controllers for all of the SATA connections (SSD is on SATA-0, two DVD Roms are on SATA-1 and SATA-2, and Storage HDD is on SATA-4. SATA-3 and SATA-5 are empty.) When I try to uninstall the Nvidia Storage Controller so I can have the default Windows 7 driver take over, it auto-installs the NVIDIA controller on reboot. So the first question: is there a way to override the Nvidia Storage Controller and have Windows use it's driver (with AHCI support) instead. EDIT: or can I install the Intel RST driver that has shown up in a few threads? Can I just use that Driver in place of the Nvidia driver?
Figuring that I wouldn't be able to get TRIM running since I couldn't get AHCI turned on, I decided to try the Toolbox instead. When I open up the ToolBox it shows me the SSD on the list at the top (as well as the 2 Partitions of my HDD) and all the buttons in the lower section are there, but I can't click on any of them. I thought it was a .NET 3.5 Framework thing, and installed the latest, but that doesn't seem to be it? This is a brand new Win7 install...is there something else I'm missing for the ToolBox buttons to work? (Java, Flash...??) or does the Toolbox need AHCI to work too?
Related to all of this, I did try to do the FW update before installing everything and when I ran the CD installer it told me that no SSD was found on my system - even though it shows up in BIOS under SATA-0. So for now I appear to be stuck with FW 02HB.
Regardless of these difficulties, the drive is running really well - but I'd like to either get TRIM up and running or at least have access to the Toolbox to be able to avoid longer term R/W degradation.
14 REPLIES 14
DZand
Contributor III
@ Bilsko:
Your screenshot of the Device Manager makes it very clear, that RAID has not been enabled.
So you should be able to replace all "NVIDIA nForce Serial ATA Controllers" by "Standard Dual Channel PCI IDE Controllers".
Only this way you will get the full Trim support.
Hello
I have exactly the same problem that "Bilsko" has. Almost the same set up aswell. A nForce 570-chip. I have gone so far with this I´m about to replace my nForrce-MB with a new Intel-based MB.
I don´t have the option of replacing the "NVIDIA nForce Serial ATA Controllers" with "Standard Dual Channel PCI IDE Controllers".
When updating to latest firmware I had to put the disk in another computer that had a Intel chip.
We must be some ppl with this problem. My X25-M 160Gb needs to be TRIMED!!
/Niklas
I have an XPS 720 with a 680i-based mobo/clunky nvidia SATA hardware and was in the same boat as you guys. Performance was fine, but I had no Trim support, no SSD Toolbox, and firmware had to be upgraded using a different machine.
To bypass the restrictive nvidia hardware, I ended up purchasing a $29 ASUS U3S6 PCI-E add-in card to control my SSD. This ended up working out very well; once the SSD was connected to the new controller, my BIOS allowed me to select it as a boot device instead of the mobo's controller. I left my bulk storage drives connected to the motherboard's SATA ports.
The U3S6 has 2 SATA 6G ports and is based on a Marvell 9123 controller. This controller is picked up by Windows as a standard AHCI device and works fine with the MS AHCI drivers. Intel's SSD Toolbox is now 100% functional and I assume Trim is working as it should since I'm using the MS drivers.
There are other add-in cards on the market based on the same controller that would do the same job. Whatever you get, just make sure it will work with the standard MS AHCI drivers.
xact - thanks for the tip. I'm looking into the ASUS card right now (also nice to have USB 3.0 for whenever that comes around too). One question on the BIOS setup - I'm assuming that since the SSD isn't plugged directly into the MoBo, it doesn't get the same Boot status as HDDs plugged into the SATA controller. You said that BIOS allowed you to select it as a Boot device; does it just show up on the list of devices like booting from USB or LAN?
I assume that since its PCI-E, that its connecting to the Southbridge at at least 500 MB/s - so there shouldn't be any throughput bottlenecks there right? My understanding is that SATA connections are typically around 300 MB/s anyways, so the PCI-E isn't slowing down the data transfer any more than the standard SATA connection would anyways.
Finally, I assume that there are no cable issues with the SATA-II cable from the SSD into the SATA6 ports on the card - the SATA connections have the same form factor for SATA-II on the SSD and the SATA6 on the card right?
Once a drive is plugged into the add-in card, the BIOS will recognize it as a boot candidate and will add it into the BIOS' "boot sequence" list along with your mobo-connected drives, mobo RAID, CD-ROM, USB, etc. So it is treated no differently than any other potentially bootable hardware. From the boot sequence list, you can enable/disable it as a boot device as well as move it up/down the priority list. (Obviously, you will want to place it at or near the top.)
Other than adding roughly one second to the boot sequence, I haven't found a downside to running the ASUS card. If you look up reviews, you'll find the device is actually PCI-E 4x and uses a bridge chip in order try to obtain enough bandwidth for 2x SATA 6G and 2x USB 3.0 devices... so it should be able to handle a single SATA II SSD with ease. (I installed mine in the 720's bottom 16x slot.) It is also cheaper than the other single-function/1x cards on the market, so seemed like a no-brainer to me.
Remember that you'll want to enable Windows' AHCI driver before switching your boot drive. Do this either A) by installing the card, booting (let Windows detect hardware), then shutting down and switching cabling/boot priority... or B) by editing the registry key in Windows before installing the card and then reconfiguring the cabling/BIOS.
