Community
cancel
Showing results for
Search instead for
Did you mean:
WKind
Will the SSD 750 1.2TB run on a 5 year old HP ProLiant DL380 G6?
Hi @all,
can I use the SSD 750 in an ProLiant DL380 G6? There is only a PCIe 2.0 slot.
thx, cu
Wolle
Community Manager
Hi Wolle,
We understand you would like to know if the Intel® SSD 750 Series can be used in your HP ProLiant DL380 Generation 6.
Based on the specs, we can see that, as you mentioned, the PCIe slot is Gen 2. We cannot guarantee the drive will work, at least as storage, since this drive uses NVMe* interface and in the manual does not really specifies this.
We strongly suggest to you to http://www8.hp.com/us/en/contact-hp/contact.html contact HP* in order to verify if this model of server supports NVMe* drives for storage.
Nestor C
Community Manager
Hi Wolle,
We'd like to know if you were able to get in contact with HP* and if you have any more questions.
We'll be waiting for your response.
Nestor C
