Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Window 7 64bit + Turbo Memory + SSD
I am using a Window 7 + 4G Trubo Memory in my Laptop. However, I recently replace the hardisk by a new 160 GB G2 SSD with latest firmware.
Regarding the use of Trim, I read the "Intel Solid-State Drive Optimizer"
http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_optimizer_white_paper_rev_2.pdf http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_optimizer_white_paper_rev_2.pdf
It tells about:
Operating SystemStorage DriverExecution EnvironmentMicrosoft Windows* 7Microsoft* AHCINative OS trim support enabled
(Intel® SSD Optimizer not required)Microsoft Windows 7Intel® Matrix Storage Manager**Intel® SSD Optimizer requiredMicrosoft Windows
Vista* orMicrosoft AHCI or Intel® Matrix Storage ManagerIntel® SSD Optimizer required
Any now..I want to ask:
1. Is it worth to use Turbo Memory in an SDD Laptop?
2. If no, I shall uninstall the turbo memory, drivers and IMSM. Then how do I know native Trim is still working properly?
3. If yes, since I have both AHCI and IMSM installed....is it still necessary to install Intel® SSD Optimizer?
Warren
Tags (3)
MBall5
New Contributor II
Hello, I would like to let you know that turbo memory is not something that we support trought this channel of support, the recommendation is to contact the place of purchase or the OEM manufacturer of your computer.
