Community
cancel
Showing results for
Search instead for
Did you mean:
LBend
Windows 10 won't start install on 545S SATA
Jump to solution
It is a DIY PC built by my own and the installation interface won't open up. The computer gets a black screen and says no bootle device found.
LeonWaksman
  1. Please reinstall Windows, following this tutorial:
  2. Please prepare your installation media (you need 8GB – 32GB USB stick), using Microsoft Media Creation Toolhttps://go.microsoft.com/fwlink/?LinkId=691209
  3. Your bios should be set to default settings. If uou have UEFI Bios, the UEFI boot should be enabled.
  4. With the installation media inserted into rear USB slot, power ON your computer, you should boot into Windows installation USB.
  5. Follow this tutorial to continue with installation https://www.tenforums.com/tutorials/1950-clean-install-windows-10-a.html
  6. In para. 7 you may enter Product Key from the Microsoft Distribution you bought.
  7. Skip on para. 12 and continue in para. 13. Important, do not format drive where you want to install Windows, rather delete all existing partitions from this drive, till you see one unallocated space.
  8. Press Next and continue with the installation.
Leon
LeonWaksman
Leon
How did you install Windows 10 (DIY)?That is what i did to install Windows 10 on SSD.
I think LWAKSMAN is right,it is best to use use Windows 10 Media Creation Tool to install Windows 10.
