Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Windows 7 x64 - SSD Firmware
Hi everyone,
I downloaded the ISO to update SSD firmware from here: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363
I burned the ISO and when I tried to run it on a Windows 7 x64, I got a message saying something like: "The program you are trying to run is incompatible with your version. Check if you need x86 or x64 and try again."
Any suggestions where I can get an ISO that will run on x64?
Thanks in advance,
DrCr4zy
Community Manager
You must boot with the CD/DVD and follow the instructions. That's all.
