Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
435 Discussions
Would Optane 900p work well as a swap drive in Ubuntu?
CBish
For some of my scientific calculations I could use up to 1 TB of memory if it was available. I was thinking that with the low latency of the Optane drives that these could work well as a swap drive, but I code in Ubuntu. Would this actually work as simply as adding it as swap space like I would any other HDD/SSD? Would it still have the same low latency?
Hello cbishop,
We would like to let you know that the U.2 version of the Intel® SSD 900p supports hotplug so you can easily swap drives within a server.
Please let us know if you have any other question.
Nestor C
Hello cbishop,
We would like to know if you have any other question or if our previous post helped you. We'll be waiting for your response.
Nestor C
CBish
The current answer isn't exactly what I was looking for. I understand that there is extra software for windows, so I wanted to know if this drive would work as a regular ssd in linux .i.e show up as a regular mountable drive. My goal would be to set it as the swap area in linux, since I have applications that require 400+ GB of memory, but not enough ram.
Hi cbishop,
About if the drive works as a regular SSD in Linux*, we can let you know that we have tested it with RHEL 7.2 and Ubuntu 15.04. As long as the operating system comes with the inbox NVMe* driver, you should be able to use it normally.
Nestor C
Hello cbishop,
We haven't heard from you in a while. Please let us know if our previous reply was helpful or if there's anything else we can do for you.
Eugenio F.
