Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
X-25V firmware update fails
When I try to run the firmware updater on my X-25V (in an Acer netbook, SATA set to AHCI) I get an error message that starts something like:
[PMODE/W] Abort: 00
Exception: 0D
followed by some more cryptic stuff. It just fails completely. Am I doing something wrong?
I'm running the updater tool from a USB stick as I don't have access to a cd drive for my netbook.
Community Manager
I wasnt aware that there was any real firmware update for the X25-v but...if there is...there should be no prob doing it by way of USB as I also have an Acer it I do everything by USB. Make sure of course your bios is recognizing the USB as its primary boot though.
Community Manager
The download page for the firmware does specify that it supports the X-25V 40GB model.
I have it set to boot from USB, and FreeDOS boots just fine - when I try to run the updater get the odd errors. It doesn't get to the stage of asking me any questions or anything - just fails with the cryptic errors.
Community Manager
Hi... does your netbook give you the option in BIOS to run in IDE (compatibility mode)? Firmware update should be done from IDE, not AHCI.
Community Manager
Ah, misread the instructions there...
I've just tried it again with the BIOS set to IDE mode and I'm getting the exact same errors.
Community Manager
I do not understand. I thought you had it figured and done? What happened?
Community Manager
It was still giving me errors, but I've just tried to run it 3 times in a row and the third time it worked for some reason. Sorry if I've wasted peoples' time and thanks for the help. The new firmware seems to be working fine now.
Community Manager
Cool, the Firmware is on. Way to go. It's always good to hear you have things work.
