Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
X25-M 120 GB
Community Manager
Just installed the X25-M in my wife's ASUS UL10 with Win 7 64 bit. Works wonderfully!
The driver is: ICH9M-E/M SATA AHCI Controller dated 6/19/09 v 8.9.0.1023. Does this driver enable the TRIM command to work?
I know that there is a more recent driver (v 9.6.0.1014, dtd 3/23/10). Does this driver enable the TRIM command? Do I need to update?
Thanks!
mmokk
New Contributor II
yes, you'll need to update to at least 9.6.0.1014 for windows 7 native trim to work.
Community Manager
I do not believe TRIM is supported by that driver. I am trying to find a changelog to be sure but Windows 7 with TRIM was released after that date.
Regardless, it is recommended that you keep your drivers up-to-date.
mmokk
New Contributor II
Community Manager
@ducky
@mister
Thank you both!
By implication in your post, mistermokkori, there is a newer driver than 1014. Please advise the driver that you would recommend. Thanks!
Community Manager
Community Manager
@duckie - Thanks!
Installed 10.1.0.1008 and works like a charm. CrystalDiskMark tests with 8.9.0.1023 (before) and 10.1.0.1008 (after) show almost identical scores so, no harm done, at least! And, now (presumably) TRIM will work.
Thanks for the help!
