My X25-M 80GB SSD was purchased in March of 2010. It is starting to fail on me after performing great for all this time. Constant blue screens and Windows prompts me to perform a back up and tells me that the drive is going to fail soon. I contacted Intel and they are going to replace it for me since its still under warranty. I no longer have the box that it came in. Will they still replace it? I have proof of purchase from Newegg. Also, since this drive is an older model that is no longer being produced or sold on Newegg(shows as deactivated), will Intel be shipping me a newer model of this drive? A SATA 6.0Gbps SSD perhaps?? Thanks for any information in this matter!
I just checked the website (Intel) and my model of SSD has reached EOL. I would think that an upgrade to a better model would be the best solution for this warranty replacement. The 520 series 120gb SATA III is only $179.00 and I paid $200 for my X25-M 80GB when it was released. I hear the newer models have a 5 year warranty now as well. I would be a real happy customer if Intel upgraded me to a better, more reliable SSD. Thanks!
The original packaging shouldn't be needed to get an RMA. The proof of purchase and the drive itself is what counts.
Regarding the replacement: The 320 series of drives are the current functional equivalents of the old X25-Ms (same controller), so that is probably what you will get if they don't have X25-m spares in stock.
Don't get your hopes up regarding the replacement capacity versus cost then and now. It's the function (capacity and speed) of the failed drive that dictates the replacement specs, not the price at the time of purchase. In other words, even if you paid $200 for your 80GB X25-M, you will get another equivalent 80GB drive even if the current drive only costs $140. That is only fair.
Thanks for the info! Like my momma always said, "It never hurts to ask!" I would be happy if they at least upgraded me to the 320 series. Are those more reliable than the X25-M's?
You're welcome.
Regarding whether the 320 Series are more reliable than the X25-Ms: In theory, yes. The 320s have an enhanced version of Intel's data protection XOR algorithm that allows more flash memory cells to fail without loosing data and a capacitor that can supply power to the drive long enough to write uncommitted data in the drive's buffer to the flash in case of an external power outage.
But there are also some reports (browse this forum) of a type of failure (the "8MB bug") of some 320 that the X25-Ms didn't seem to have, so YMMV. The X25-M wasn't known as an unreliable drive, quite the opposite compared to contemporary SSDs, so you must just have had some bad luck with yours.
Employ a sensible data backup strategy (no matter what drive you use) and don't worry too much about the risk of drive failure. I own and use multiple versions of both the X25-Ms and the 320s and have never had a failure.
BTW, you should run a Intel SSD toolkit diagnostic and check/post the s.m.a.r.t. data and media wearout indicator before you send off the old drive, so you can get an idea of what may be the cause for the seemingly early death of your drive. When you get the new drive, change the sata cable as well just to rule out a bad connection. The cables are dirt cheap anyway.
Thanks again for the info! I will run the SSD diagnostic toolkit like you have suggested. This drive has never given me problems till now. I thought it was odd that it started failing out of nowhere. I have plenty of spare SATA cables since I'm always building PC's at work. Thanks!
Interesting. Attribute 233 (0xe9) is the Media Wearout Indicator and a value of 99 is normal for a two year old drive that has seen some action as an OS/application drive.
The End To End Error Count is clearly the issue. That could be caused by a bad electrical connection between the drive and mainboard. Have you tried another sata cable and/or connecting it to another controller port?
I took the drive in to work with me this morning and connected it to a brand new ASUS P8Z68-V Pro/Gen3 motherboard with new SATA cables. As soon as I powered on the computer it stopped mid POST and states,
SATA Port 1 :Intel SSDSA2M080G2GC
S.M.A.R.T Status Bad, Backup and Replace.
Press F1 to Run SETUP
I booted the system into a Ghost boot CD and used our Ghost cast server to put a fresh, working Windows 7 64bit Pro image on the SSD. Once the imaging was complete, I rebooted and got the same SMART warning as above. I forced the system to boot the SSD from the BIOS and was able to start up Windows. I then downloaded and installed the Intel toolbox and got the SMART data CSV file and took a screenshot.
The parts in this computer at work are all brand new and confirmed working. I have another SSD from a different manufacturer that works in the system just fine. Been running benchmarks all week and stress testing the system. I know I already have the RMA process going and the Intel drive needs to be replaced, but it's odd how it now decides to fail after all this time. I wonder what caused the fail?
Message was edited by: Phil Anderson
Just contact Intel and provide what you found about this SSD, you should get a same X-25M 80GB unit soon
