Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
X25-M G2 80GB benchmarks look good?
Community Manager
just got a x25-m g2 drive and first thing was to update firmware then installed the os.
i've read that intel drivers dont support trim yet so i stuck with windows 7 ahci drivers (x64)
i went around google and compared my benchmarks and some of mines seem off..
i have tried ssd toolbox, as-cleaner. and still the score turns out around 310-330 on AS SSD
does anyone have any suggestions to improve them, particularly the 4k write is about half of everyone else's that I saw
or do these look good (that I wont notice)?
Thanks!
Community Manager
Your sequential read/write numbers look correct. There are some performance benefits on the 160GB drives vs the 80GB drives. So keep that in mind for comparison purposes.
Community Manager
I'd say those numbers are not so good. The access times seem to be a problem. Have you disabled write cache? If so enable it and you should; see an improvement. Below is a comparison from my 80GB G2.
AS SSD Benchmark 1.2.3506.28865
Name: INTEL SSDSA2M080G2GC ATA Device
Firmware: 2CV102G9
Interface: IDE
Date: 25/08/2009 13:01:08
Sequential:
Read: 255.83 MB/s
Write: 80.39 MB/s
4K:
Read: 24.81 MB/s
Write: 45.00 MB/s
4K-64Threads:
Read: 151.56 MB/s
Write: 53.66 MB/s
Access Times:
Read: 0.066 ms
Write: 0.084 ms
Score:
Read: 202
Write: 107
Total: 413
Community Manager
I have enabled it, anything else I should check?
Could it be faulty?
Community Manager
I only change the following from a standard Win 7 install:
Turn off degrag
Turn off system restore: Free up space and make trim run a lot faster. (I use Win 7 disk image for back up)
Turn off hibernate: Free up space
Turn off superfetch
What mobo are you using? Nvidia and AMD based boards don't seem to be as good as Intel based boards when it comes to ssd.
Community Manager
ok, all of that done. first things i did when i installed the os
umm the mobo is.. im not sure, since its my laptop. lenovo thinkpad t500, p8600
i'm thinking about formatting it and trying it on my desktop, asus p5b-deluxe
Community Manager
I wouldn`t do anything more. I`ve a laptop too and I`ve similar results.
We`re getting these speeds because of the structure of the laptop.
You would have better results with the desktop computer.
All the best!
Community Manager
oh really?.. I thought it would be a problem
I might try it tonight on desktop to see if it really performs the way it should
these shouldnt make much of a real world difference, should they? the speeds
Community Manager
My lenovo thinkpad x200 has never benched below 0.12ms for either read or write access times. Not sure what to make of it but I'm not going to stress out about it anymore. I've tweaked W7 to high heaven and back.
