Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
X25-M G2 sequential read and other questions
I have Intel X25-M G2 160GB SSD drive. It works great! However there is one thing I am...cuorius about.
Please look and the linear transfer rate graph below:
You can see some dips in the line at the beginning then at 50 percent mark.
When I just installed windows 7 there was only a little dip at the beginning, now after drive is working 141 hours and 28 percent of space is filled you can see more oh those dips in linear graph. They are consistent and repeated tests show simmilar pattern.
I am in no way dissapointed with this drive, it worked very fast and works very fast just as before, I am just curious what it is.
Rest of the system specs:
Windows 7 Home Premium
AHCI drivers by Microsoft
BIOS set to AHCI mode
Core 2 Duo E8200
8GB of RAM
Asus P5E (X38) motherboard
Currently no HDD is connected
I updated firmware to the newest 02HD before windows 7 install and did a clean install formating SSD.
There is ONE MORE thing...during firmware update from boot cd I got a message about update error and suggestions to SATA to IDE mode and try again.
However, when I tried again I got a message that firmware is already updated. I check with HDTune and HDD Sentinel an they both also show firmware to be up to date. So I quess it's fine then?
Community Manager
Now when there is more data on the drive there is more of this phenomena too. It seems sequential read line dips where data is. If I delete data it gets back to full speed in that place It's not dramatic but it's here and I wonder why.
